Junction box connector - Druckversion +- GPZ Forum (https://gpz.info) +-- Forum: Technik (https://gpz.info/forumdisplay.php?fid=3) +--- Forum: Technik (https://gpz.info/forumdisplay.php?fid=23) +---- Forum: Elektronik (https://gpz.info/forumdisplay.php?fid=25) +---- Thema: Junction box connector (/showthread.php?tid=9768) |
Junction box connector - veki - 05.04.2013 Can you tell me where it goes red black wire from junction box connector? (Gpz500s 1989. ) Können Sie mir sagen, wo es rot schwarzen Draht geht von Dosenklemme? (GPZ500S 1989.) Greeting from Croatia! Re: Junction box connector - _42_ - 06.04.2013 Might check this out: <!-- m --><a class="postlink" target="_blank" href="http://www.klappersaki.de/gpz-wartung/buecher/schaltplan_a-modell.jpg">http://www.klappersaki.de/gpz-wartung/b ... modell.jpg</a><!-- m --> Even if I still struggle at looking straight foreward at this time, it should be the source for the (Kill-)switch on the sidestand. Re: Junction box connector - veki - 06.04.2013 Thanks, I know thats wire of side stand swich but I dont know where its go, in hole 1 or 2 or 3. Heres a picture. Re: Junction box connector - flitzdüse89 - 06.04.2013 Hello, the red-black wire goes to the first hole, at the left arrow from your picture. I've looked at the wiring harness from my 1989 Model, EX500 B2, I think that's the same model as yours. Greeting from Black Forest (Germany) Sabse Re: Junction box connector - veki - 06.04.2013 Thank you very much Re: Junction box connector - flitzdüse89 - 07.04.2013 No problem I noticed, that two wires from your picture are missing in my plug, in the under row, the orange-white and the blue wire doesn't exist at my plug. All others are the same as on your picture. Do you know, for what these two wires are? Maybe for something, what was only for US-Models, not for the german models? Re: Junction box connector - veki - 08.04.2013 My GPZ is european model (except Italy). Orange-white doesn't exist, only red-white (at the picture red color looks like orange) Blue wire is for cooling fan, One white-red is for cooling fan switch (radiator), second white-red is for I.C. igniter. But on scheme not shown order of wires in connector, so I said where go both red-white wires. Re: Junction box connector - flitzdüse89 - 10.04.2013 Thank you I've got a second wiring harness in reserve, and it's the same there, these 2 wires doesn't exist at this plug from the german models. So I think, that's ok so, because everything works how it should, even without those wires. If they were important for my model, something couldn't work correctly. But that's not the case, everything's alright. I only asked out of interest... I remember, that another user in this forum had problems with the wiring connection from the radiator / cooling fan. HERE are two different variations of radiators. Maybe he had the radiator from an european model, that doesn't fit to a german GPZ. Have a nice day, Sabse |
