Might check this out: <!-- m --><a class="postlink" target="_blank" href="http://www.klappersaki.de/gpz-wartung/buecher/schaltplan_a-modell.jpg">http://www.klappersaki.de/gpz-wartung/b ... modell.jpg</a><!-- m -->
Even if I still struggle at looking straight foreward at this time, it should be the source for the (Kill-)switch on the sidestand.
***Signatur verschlüsselt***
I noticed, that two wires from your picture are missing in my plug, in the under row, the orange-white and the blue wire doesn't exist at my plug. All others are the same as on your picture.
Do you know, for what these two wires are? Maybe for something, what was only for US-Models, not for the german models?
My GPZ is european model (except Italy).
Orange-white doesn't exist, only red-white (at the picture red color looks like orange)
Blue wire is for cooling fan, One white-red is for cooling fan switch (radiator), second white-red is for I.C. igniter. But on scheme not shown order of wires in connector, so I said where go both red-white wires.
I've got a second wiring harness in reserve, and it's the same there, these 2 wires doesn't exist at this plug from the german models.
So I think, that's ok so, because everything works how it should, even without those wires. If they were important for my model, something couldn't work correctly. But that's not the case, everything's alright. I only asked out of interest...
I remember, that another user in this forum had problems with the wiring connection from the radiator / cooling fan. HERE are two different variations of radiators. Maybe he had the radiator from an european model, that doesn't fit to a german GPZ.
Have a nice day,
Sabse
